Every time i load up Main Concept Mpeg Encoder Register Version to convert my xvid avi file it just closes its self down no warning or error msg. This also happens with Ulead DVD workshop 1 and 2 both registered versions and TMPEnc Source Creator and TMPEnc the free one. Any ideas? all the software is the lastest versions, i am running XP with all the lastest releases.
Thanks in Advance
Andrew
Just to be safe, install the latest Xvid codec. If that doesn't help you probably have a damaged file(even if it plays fine). Use this guide to check for bad frames.
VirtualDub/Xvid question: YV12 vs. XVID FourCC in the xvidvfw.dll driver???
By KneeRow in forum Video ConversionReplies: 14Last Post: 1st Aug 2010, 13:35 -
Does xvid cli (command line version of xvid) actually exist ?
By vhelp in forum ProgrammingReplies: 10Last Post: 29th Oct 2009, 14:18 -
help combining 2 xvid avis and 2 subtitles (srt) to 1 xvid avi
By hibbs in forum SubtitleReplies: 4Last Post: 14th Jun 2009, 19:05 -
How to encode an xvid file to another xvid and prevent video blocking?
By BlooderButcher in forum Video ConversionReplies: 5Last Post: 21st Nov 2008, 16:03 -
Weird I don't have XviD or DivX codec installed but I can see Xvid movies
By Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 11:47
