Would like to edit or add chapters and transitions to product created. PowerDVD plays without a hitch, but WinXP does not see files and gives message to insert disk into drive. Same oodurs with MM2
Results 1 to 10 of 10
God Bless
Thank you for your response.
Yes, it is a finalized DVD-RW in VR mode, but It also doesn't read a finalized dvd-r, that plays fine in PowerDVD.
I am considering DVD MovieFactory 3 Disc Creator. Will it make transitions?
In past I have used CanpusADVC100 to Pinnacle7, edit, cut, transition, titles, then to MF2 for chapters and menu creation and to burn.
I like the use of transitions because it smooths the play between the cuts.Where would I find such file system driver ?These discs do not require finalising however need file system driver support to readable under Windows Explorer.
This is correct. After I eventually convert all of home movies to DVD. i would like to be able to take a snippit of this one and that one, etc to make a single video. Say Christmas or birthdays over the years or a growing up video for my kids when they get older.I suspect you want you create an ordinarly DVD-R/+R with a menu for other DVD PlayersGod Bless -
I have the Pioneer 310 and i'm having the same trouble. In my PC i'm using the Pioneer P-105 DVD writer for reading the discs and it still can't be done. Record the discs in video mode and it'll read no problem.
PhilipL, could you please post link ? I was not able to find it. Thanks.
Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
Great.. Thanks.
DirecTV DVR: how do I get to my computer to record to DVD?
By hyphenate in forum DVD & Blu-ray RecordersReplies: 10Last Post: 25th Dec 2009, 10:54 -
Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
By psymaster in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2009, 20:48 -
By psymaster in forum Latest Video NewsReplies: 1Last Post: 31st Oct 2009, 18:26 -
Can you read DVD's from DVR's on the computer?
By feeman_4_life in forum DVD & Blu-ray RecordersReplies: 2Last Post: 30th Sep 2007, 03:34 -
Can tabletop dvd recorder attach to a computer and also to a dvr, separatel
By ItsMikeMazz in forum DVD & Blu-ray RecordersReplies: 7Last Post: 20th Jul 2007, 19:26
