From experience when decoding form a dvd what is the best corse of action... A Xvid, Mencoder MPEG4 or ffmpeg Ripp?
cheers for your comments![]()
generikGuest
The only applications that decode MPEG-2 streams that ffmpegX uses are mencoder and Quicktime.
ffmpegX can ENCODE a ripped DVD file using the Xvid format, DivX, MPEG1, and MPEG2, and some others, but those are the most popularly used.
Xvid and DivX are almost the same (Xvid is an open-source version of DivX). The differences are too technical for me to explain, but as far as personal preference goes, that really is determined by your source file. Different encoders encode different video sequences in different ways. The best way to figure out what'll work best for you, is to experiment. See what gives you the best picture with the best filesize.
MPEG1 and MPEG2 won't give you the quality the MPEG-4 (Xvid and Divx are MPEG-4 variants) will in terms of filesize and quality. What I mean is, to get the same quality, your file will be a lot larger.
Just play around with different settings, bitrates, image sizes, etc.
If I'm wrong anywhere here, someone please correct me
Converting from xvid avi to mpeg-2
By busbee2 in forum Video ConversionReplies: 5Last Post: 13th Dec 2009, 00:44 -
XviD MPEG-4 to DVD with Subtitles
By MI6 in forum Video ConversionReplies: 1Last Post: 3rd Jan 2009, 06:09 -
MPEG-4 Playback Means DivX/XviD, Right?
By p_l in forum DVD & Blu-ray PlayersReplies: 1Last Post: 21st Dec 2007, 22:32 -
xvid to mpeg 2
By DSLGuy in forum Video ConversionReplies: 2Last Post: 13th Oct 2007, 12:27 -
h.264/MPEG-4 to 2-pass XviD (.avi)
By lalala in forum Video ConversionReplies: 4Last Post: 9th Sep 2007, 21:19
