Does anyone know a burning tool that would allow to burn divx/avi files in mode 2/form2 (used for (S)VCD) ?
I think this way I could fit 800Mb of data on a 80min CDR.
I tried nero and VCDimager, but both check if the file is an mpeg file before burning/creating the image.
SVCDs and VCDs must have their source files in MPEG-1 and MPEG-2 respectively.
If you want to put DivX onto a S/VCD, you will thus have to convert it to MPEG-1/2 first.
<--- There are guides on how to do this on the menu to your left...
Good luck.
Regards.
Michael Tam
w: Morsels of Evidence
Really bad DivX's using "HD" mode in DivX Plus Converter
By sjdean in forum Video ConversionReplies: 37Last Post: 22nd Oct 2011, 08:31 -
DVD Decrypter: File Mode total size double that of ISO read mode
By dare2be in forum DVD RippingReplies: 7Last Post: 13th Feb 2011, 12:21 -
JVC HR 9600....edit mode vs auto mode for digitizing s vhs or vhs
By fuzzblaster in forum Capturing and VCRReplies: 21Last Post: 21st Jan 2011, 08:28 -
shrink avi/divx in batch mode
By volam1 in forum EditingReplies: 1Last Post: 5th Jan 2010, 20:20 -
Advantages of ripping in File mode over ISO mode...
By hiimbored in forum DVD RippingReplies: 9Last Post: 5th Jun 2008, 15:27
