I have a cendyne 52x cd-rw drive, when using nero i want to use 2x or 4x to burn an svcd, but the only options that nero gives me are 8x up to 52x. Before i put the cd-r media in the drive, I have a 4x option, but once i put the disc in the option disappears. Is this a problem with the brand of disc(TDK). Do some brands of cd-r's only allow a certain minimum speed they can be written at? Thanks
When I play my svcd's with the header trick on my dvd player, the video and audio is pretty choppy. I want to try burning at a slower speed to see if it will make it any better, or if it just isnt compatible with my dvd player.
I have Nero 6. I tested mines with with 48x HP Invernt cd and it gave me
options of burning it at
40x
32x
24x
20x
16x
12x
8x
4x
My burner is Sony 40x/12x/48x.
I guess it's your cds but really I don't know
Good luck -
Check cendyne for any firmware updates to the drive.
Nero has a utility that might be some help.
Dynamic Write Speed off
"Download DynWrSpeed_Off.zip and extract the zipped files onto your hard disk using WinZip or WinRar.
Run the registry patch contained in the zipped file by double-clicking it.
It modifies Nero so that the speeds supported by the recorder can no longer be calculated dynamically but is derived from a table in the burner's firmware.
Nero should now, at the latest, display all speeds supported by the burner provided that there is no recordable CD in the burner. "
[EDIT] I checked a TDK CD R disk in a Plextor PX 708A and the write values are the same as slimmx. -
your problem is not with burning spped it is more likely that your player is not svcd compatible esp if you need to run the header trick.
The electronic components of the power part adopted a lot of Rubycons.
Media does not burn at advertised speeds.
By nick101181 in forum MediaReplies: 14Last Post: 27th Feb 2010, 17:44 -
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 20:49 -
Extremely low burn speeds, High CPU usage
By BetaMaster in forum Authoring (DVD)Replies: 13Last Post: 20th Nov 2008, 13:23 -
relative quality and best burn speeds for some popular media
By JohnnyBob in forum MediaReplies: 32Last Post: 8th Feb 2008, 18:44 -
Can't get rid of PIO, Slow burn speeds
By ER_Doc in forum DVD & Blu-ray WritersReplies: 9Last Post: 19th Jul 2007, 23:28
