Results 1 to 12 of 12
  1. im using tempeng and i madae a mpeg 2 but the quality of it is the same as the original video how do i make it better quality
  2. When you encode or resize a video you lower the quality
    You cant encode a low quality video (mpg) and encode with divx to make it dvd quality it will look worse than what you started out with
    You can only go from High quality video to low quality video
    8)
  3. so is there anyway i can make the picture quality look good
  4. If the video you have is low quality their is nothing you can really do for it but you can use filters to help it look better
  5. wat filters can i use and how do i use them
  6. In TMPGEnc go in to settings, double on either edge enhancement, or
    color correction, use both to make the video look a little better
    Use filters like edge enhancement (sharpen video), color correction (helps video picture some
    But other than that there is no help for the quality
  7. Member teegee420's Avatar
    Dec 2003
    Southern California
    Jesus, I thought my signature was big! Can you describe the characteristics of the video that you consider to be poor?
  8. it's a wmv and a mpeg
    canada
    Good description
  10. Member teegee420's Avatar
    Dec 2003
    Southern California
    *throws hands up in defeat*
    Where exactly does one go from here?
  11. i want the quality good im trying to convert an wmv and mpeg1 video to a mpe2 video and i want the quality good
  12. Member teegee420's Avatar
    Dec 2003
    Southern California
    Man, am I tempted to use that one in my sig...
    The first thing you should learn about this hobby is that you need to start with a great source to end up with a decent destination file. You can even start with a good source and end up with an ok file, but you absolutely CAN'T start with a bad source and end up with a great file. To make a long story short, you can't turn shit into gold. If you want a nicer video, make one yourself from the original source.
