I have 11 episodic clips which I've converted to standard VCD format with TMPGenc. Each resulting MPEG file plays normally with no audio sync issues. I then author them with TMPGenc DVD Author as DVD @ 352x240, no problem. When I play the disc (or vob files) on my computer, all the clips play fine, but when I play the DVD on my set top the last clip has audio sync issues.
I've gone nuts trying to figure this out, I've scanned the original divx's and xvid's for errors, saved audio streams as PCM, rechecked each file so that it is exactly the same as all the others but nada, nothing. Any ideas would be appreciated.
Also, if anyone knows: Is it better to burn DVD's with Tmpgenc's built in DVD writing tool or burn the Video_TS folder with Nero?
Thanks in advance for any replies.
DF
All I can think of is: Tmpgenc VCD template samples audio at 44,100k, but DVD compliant files is 48k, so Author must resample the audio. . .
I would suspect a problem in the original file and start testing there myself. Does the original file play correctly in VirtualDub or is it outosync? That would be my first test.
Good luck.
TMPGEnc DVD Author 3 gradually loses audio sync
By timmus in forum Authoring (DVD)Replies: 1Last Post: 6th May 2009, 17:24 -
TMPGEnc Dvd author 3 problem
By prcole18 in forum Authoring (DVD)Replies: 7Last Post: 7th Oct 2008, 11:33 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
Baffled by conversion problem
By vvw in forum DVD RippingReplies: 9Last Post: 25th Feb 2008, 13:14 -
TMPGEnc DVD Author 3 - Playback problem, Help!
By cbales_24 in forum Authoring (DVD)Replies: 2Last Post: 18th Oct 2007, 16:29
