It reads the dvd-r only on occasion. It seems like this problem came out of nowhere.The drive can read everything else (dvd's cdr ext...)
I was backing up a movie it seemed like everything was fine but when i press the eject button it dosnt open the drive. the only time it will open after that is when i reboot. Also now it only is recognized as 1x.
Unless you are having other problems with your computer, or you have recently installed programs that may interfere with your burner, it sounds like the burner itself is going bad. You can try a few of the standard 'cures'; Restore to an earlier setup (If you are using XP), delete your IDE controllers and let the OS reinstall, Use Nero Info Tool 207 to see what your drive setup is, and probably a few more I can't think of just now.
DVD Decrypter Not Reading Devices
By JoRodd in forum DVD RippingReplies: 4Last Post: 14th Apr 2009, 14:33 -
Error Reading by GOM and Media Player Classic in reading MKV video
By cutefix in forum Software PlayingReplies: 1Last Post: 31st Mar 2009, 01:25 -
Reading non-finalized DVD's?
By Noiseworker in forum Authoring (DVD)Replies: 9Last Post: 7th Jan 2009, 19:37 -
Pioneer 112D - Dissapears from Devices when reading a disc at 50%
By faramith in forum DVD & Blu-ray WritersReplies: 4Last Post: 6th Nov 2007, 13:46 -
Pioneer 106D & Maxell 8x DVD-R
By piano632 in forum DVD & Blu-ray WritersReplies: 1Last Post: 22nd Jun 2007, 18:38
