Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
  1. I want to get a new Lens because i would like to start making some really high quality DVD's with my new DVD Burner. I was wondering what would be the best lens to get money is no problem im look from 299.99 to 399.99 or more. Please let me know which ones are good, that will benifit me with better quality homemade DVD's
    Please look at this page and let me know which one is what i need
    http://www.sonystyle.com/is-bin/INTERSHOP.enfinity/eCS/Store/en/-/USD/SY_BrowseCatalog...lters&Dept=dcc
    Jan 2001
    Brisbane, Australia
    find out what the filter ring size on your camera is and go with a wide angle to suit
    Unless you are doing extreme long distance anymore zoom is probably overkill
    Mild wide angle again not extreme is good for some family shooting
    Jan 2001
    Brisbane, Australia
    Good for you
    just make sure it fits the camera
  4. Member joecav's Avatar
    Philadelphia, PA USA
    Just as an FYI....for future reference.
    Try and check B & H when looking for camera equipment (if you're in the US) They have the same lens (and a multitude of others) for cheaper prices and they are a quality e-tailer. Your particular lens is not currently in stock, but it is (was) about $50 cheaper.
    LINKY
    Of course, if you don't care about saving a buck or fifty, disregard. Hope this helps.
    **EDIT** they have a used one in good shape for $99 too
  5. I would second B&H. They're probably the most reputable dealer in the country. The best customer service hands down.
