i am trying to merge 2 avi files (virtual dub)- i click save as avi & it seems to go ok for a while then reports :Error:Cannot seek within file"etc.avi":The parameter is incorrect, then stops - what must i look for
Scan the file for bad frames. If none are found, go ahead and save it under a new filename and ss if that works.
Hello. -
tried saving with diff name & seems theres no problems with the 2 files - HELP !!!
Try virtual dub mod ,it has help for me to merge a couple files the would not merge in virtual dub
MKV to AVI in Virtual Dub With AviSynth :?: :!:
By ineedhelp123 in forum Video ConversionReplies: 28Last Post: 21st Jul 2008, 16:08 -
virtual dub choppy avi
By bigwheels103 in forum Newbie / General discussionsReplies: 2Last Post: 24th Oct 2007, 21:27 -
virtual dub logo avi too big
By forchristians in forum EditingReplies: 5Last Post: 20th Sep 2007, 23:47 -
Audio problems with Plextor M402U and Virtual Dub
By nrsgzz in forum Capturing and VCRReplies: 4Last Post: 6th Sep 2007, 18:27 -
AVI to DVD w/ Virtual Dub
By hawsonggook in forum Authoring (DVD)Replies: 1Last Post: 15th Jun 2007, 02:58
