I said I would post this problem in here for someone who is having problems burning DVD's,
so here goes... any help appreciated :-
Bought the computer new last May its an Advent 3316, 3.06GHz, windoze XP home, but only had a cd writer on so I bought a Philips DVD+R/RW drive to go with it. The drive was fitted and the software that came with it was Nero basic package.
I downloaded some films from kazaa but as I said they are ones that are out legally on dvd/video and so the quality is really good. Also now got Nero 6 (which I believe is installed?)
I am directed to use NeroVision Express 2 to burn the film. After following instructions to obtain the film from the folder it is in I press the 'burn' button. It says it is "creating menus and transcoding" and this process takes 3 hrs 45 minutes (is that right, seems so long to me?). The film is approx 100 minutes long. Then I am asked to insert a disc in. I am using the free Philips DVD+RW disc which came with the drive. It is 120 minutes or 4.7GB. As it came with the drive it should be completely compatible BUT a minute after I insert it, it comes back out with a box saying:
"There is not enough space to burn this compilation to this disc. Please insert another disc that has enough space" Also it says "NOTE: you will not need to transcode again if you cancel the recording now unless you change the project data afterwards"
So I just press the 'cancel' button - what else can I do?
I just tried to burn half a film called Oceans Eleven. Think its less than an hour in length and after it did the 'transcoding' bit I put the same dvd in and it ejected it saying:
"Burn process failed" An error log was created do you wish to save it" I have the error log, its quite big... the only bit I can see with errors is :-
[13:35:43] NeroVision 13:34:11 #16 Phase 36 File APIProgress.cpp, Line 253
[13:35:43] NeroVision Burn process started at 2.4x (3,324 KB/s)
[13:35:43] NeroVision 13:34:11 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2264
[13:35:43] NeroVision Verifying disc position of item 0 (relocatable, disc pos, no patch
infos, orig at #0): write at #0
[13:35:43] NeroVision 13:34:11 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2264
[13:35:43] NeroVision Verifying disc position of item 1 (relocatable, no disc pos, no
patch infos, orig at #0): write at #0
[13:35:43] NeroVision 13:34:11 #19 SCSI -1066 File Cdrdrv.cpp, Line 1171
[13:35:43] NeroVision SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x03B25000
[13:35:43] NeroVision Status: 0x04 (0x01, SCSI_ERR)
[13:35:43] NeroVision HA-Status 0x00 (0x00, OK)
[13:35:43] NeroVision TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
[13:35:43] NeroVision Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
[13:35:43] NeroVision Sense Code: 0x24
[13:35:43] NeroVision Sense Qual: 0x00
[13:35:43] NeroVision CDB Data: 0xAD 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x08 0x04 0x00
0x00
[13:35:43] NeroVision Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0C
[13:35:43] NeroVision 0x00 0x00 0x00 0x00 0x24 0x00
[13:35:43] NeroVision 13:34:11 #20 Phase 98 File APIProgress.cpp, Line 253
[13:35:43] NeroVision Start formatting disc before burning
[13:35:43] NeroVision 13:34:24 #21 Phase 100 File APIProgress.cpp, Line 253
[13:35:43] NeroVision Formatting disc was successful
[13:35:43] NeroVision 13:34:24 #22 Phase 65 File APIProgress.cpp, Line 253
[13:35:43] NeroVision 13:34:24 #23 Text 0 File DVDPlusRW.cpp, Line 564
[13:35:43] NeroVision Start write address at LBA 0
[13:35:43] NeroVision DVD high compatibility mode: Yes
[13:35:43] NeroVision 13:34:29 #24 SCSI -1046 File Cdrdrv.cpp, Line 1431
[13:35:43] NeroVision SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x05590000
[13:35:43] NeroVision Sense Code: 0x30
[13:35:43] NeroVision Sense Qual: 0x10
[13:35:43] NeroVision CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00
0x00
[13:35:43] NeroVision 0x00 0x00 0x00 0x00 0x30 0x10
[13:35:43] NeroVision 13:34:29 #25 CDR -1046 File Writer.cpp, Line 301
[13:35:43] NeroVision Illegal disc
[13:35:43] NeroVision 13:34:29 #26 Text 0 File ThreadedTransfer.cpp, Line 229
[13:35:43] NeroVision all writers idle, stopping conversion
[13:35:43] NeroVision 13:34:29 #27 Text 0 File ThreadedTransfer.cpp, Line 223
[13:35:43] NeroVision conversion idle, stopping reader
[13:35:43] NeroVision 13:34:29 #28 SCSI -1046 File Cdrdrv.cpp, Line 1171
[13:35:43] NeroVision CDB Data: 0xF9 0x06 0x01 0xFF 0x00 0x00 0x00 0x00 0x00 0x00 0x00
0x00
[13:35:43] NeroVision 13:34:29 #29 Text 0 File DVDR.cpp, Line 4034
[13:35:43] NeroVision Drive: PHILIPS DVDRW228
[13:35:43] NeroVision Book Type request: DVD-ROM
[13:35:43] NeroVision Changing the book type was finish with error code: -1046
[13:35:43] NeroVision 13:34:29 #30 Phase 38 File APIProgress.cpp, Line 253
[13:35:43] NeroVision Burn process failed at 2.4x (3,324 KB/s)
Could also the problem be linked to using a DVDRW disc? Also, personally, I use GearPro Professional for doing CDRW, and this has a DVD option... think she'd be better using that than nero?
Please read the rules on this forum -- NO warez... next time you get a warning -- thank you for your cooperation - bjm
Closed Thread
OK guys, thanks for the responses.
I agree, maybe she shouldn't be doing what she is... I wouldn't know, I don't own a DVD (player or rewriter). I'm happy to stick with VCR and dolby pro-logic
Personally, having looked at the problems on here I think I am still making the right choice there!
I didn't get her into this mess though, someone else did... I was merely trying to see if I could help her out of it via posting on some forums. I couldn't personally give a flying fig as, like you say, its not my problem, and looking at your replies, its not yours either!! :P
Thanks again.
Suggest your friend try burning some simple data files and see if that creates a valid disk.
Next, she needs to do some research so that she would learn that of all the encoders out there, Nero is quite possibly the worst available.
Then would be a DVD rip to test with files known to be valid video.
She is starting with a file with a high probability of being garbage, using an encoder of low quality, and brand-new hardware which may not be installed correctly. ISOLATE and IDENTIFY.
Stream from friend to friend program easy to make?
By Homebrew77 in forum Video Streaming DownloadingReplies: 0Last Post: 30th May 2011, 06:27 -
low end quadro is 5 times faster than high end gaming card
By deadrats in forum ComputerReplies: 4Last Post: 7th Apr 2011, 15:42 -
Help w/ Subtitling For My Deaf Friend?
By angelatc in forum SubtitleReplies: 23Last Post: 23rd Sep 2009, 00:11 -
Player suggestion for a friend in the UK
By Faustus in forum DVD & Blu-ray PlayersReplies: 9Last Post: 6th Aug 2008, 08:22 -
Need an American 'friend'
By Gordo_ in forum Off topicReplies: 9Last Post: 4th Jun 2007, 09:36
