    Aug 2002
    Australia
    Does anyone know who makes this media
    egion information N/A not a DVD-VIDEO
    Media code/Manufacturer ID GSC002
    Format Capacity Not Formatted
    Free Blocks 411107328
    Free Capacity 4.38GB(4.71GB)
    Book Type DVD-R
    Media Type DVD-R
    Media Id Code Speed Unknown
    Available Write Descriptor CLV 4.0x 5540KBps
    Available Write Descriptor CLV 2.0x 2770KBps
    Available Write Descriptor CLV 1.0x 1385KBps
    Write Strategy Speed 4.0x 5540KBps
    2x Speed OPC beta 09
    2x Speed OPC power 11
    2x Write Strategy field 1 11 87 78 90
    2x Write Strategy field 2 A8 82 00 20 00 00
    4x Speed OPC beta 05
    4x Speed OPC power 16
    4x Write Strategy field 1 0D 10 0A 09
    4x Write Strategy field 2 97 07 0E 0B
    4x Write Strategy field 3 C0 00 00 00
    4x Speed OPC beta multi-pulse 07
    4x Speed OPC power multi-pulse 1C
    4x Write Strategy field 4 13 A8 89 65
    4x Write Strategy field 5 B6 89 88 80 00 00
    4x Write Strategy field 6 00 00 D0 00 00
    Data area starting sector 30000h
    Linear Density 0.267um/bit
    Track Density 0.74um/track
    Number of Layers 1
  2. Guest
    Guest
    I had the same question.
    check out the thread
    https://www.videohelp.com/forum/viewtopic.php?t=202567&highlight=
  3. DVD-R discs with the GSC001 or GSC002 manufacturer's IDs are made by Gigastorage Corporation of Taiwan.
    Aug 2002
    Australia
    thanks for the reply I have never heard of Gigastorage I hope they turn out to be good dvds
