  1. hi can anyone please help me i am trying to copy one dvdr to another dvdr in one step ie i put the original dvdr int he top drive and a blank dvdr in the bottom drive and press copy.
    i cannot use nero as it uses iso mode and the program aborts at aprox 94% (i can only imagine why ?)
    any ideas ?
  2. use dvd decrypter.... rip it to the hard drive, and then burn it to the dvd.
    thats the best way to do it.
  3. thanks for your reply however i would like to do in one step like in nero but not in iso mode
  4. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    Right Behind You. . .
    Try Copytodvd it is a freeware
    What We Do In Life, Echoes In Eternity....
  5. thankyou for your ansa i will try copytodvd.
    shame i cant use nero though isnt it ?
  6. Try Copytodvd it is a freeware
    since when? good for 30 as trialware.
  7. Banned
    Dec 2002
    any ideas ?
    if it aborts at 94% there must be a problem reading the source disk. check if it is clean. also check your hard drive space. and are you using ntfs?
  8. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    That's right it has a 30 trail......Forgot about that.....so it's not a freeware, unless you just keep downloading newer versions. I'd recommend buying if you like though
