  1. Hi, which software for Windows 98 SE would you recommend me to add subtitles to a DVD? Let me explain, I've got the subtitles file in any standard format (let's say .SRT) and the ready-to-burn DVD file structure in my HD. The farthest I've gone is converting the text to BMP frames, but I don't know how to inject them into VOB files. Please remember, under Windows 98 SE. Thanks!
    Apr 2002
    The State of Frustration
    See if SRT2SUP can convert the subtitles into .sup format. Then, if IfoEdit can run on your system use it to add to your DVD files.
    Hello.
  3. Thanks a lot, Tommyknocker, I'll try it right now
    P.S.: there's some nice song titled Flying Dutchman by Jethro Tull, give it a try
