Hi
Is there any software for controlling the pitch of the audio song (not tempo) which supports various formats like wav, cda. mp3 etc. The closest I found is a plugin called pacemaker that goes along with winamp. But the problem is that it does not support cda format. Whenever I try to run a cda from cd rom it quits the program (illegal operation error). It does play mp3 well.
soundforge , wavelab , vegas , cooledit (audition now) , protools , goldwave , etc ....... all of these can do pitch changes
there is also a ton of hardware to do this -- even autotuners ..
you don't think "rock stars" can accually sing in key ?"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Audacity no pitch change
By ranosb in forum AudioReplies: 21Last Post: 15th Sep 2012, 21:56 -
How do I completely remove audio over a certain pitch?
By z-kun in forum AudioReplies: 3Last Post: 10th Mar 2010, 09:19 -
Selectable Output Control - MPAA's new control tactic
By akrako1 in forum Latest Video NewsReplies: 2Last Post: 7th Aug 2008, 21:05 -
what software converts to DVD with manual video bitrate control
By perfection in forum Newbie / General discussionsReplies: 1Last Post: 2nd Jun 2008, 12:09 -
Audio Pitch Problem
By Bully9 in forum AudioReplies: 6Last Post: 18th Jan 2008, 01:41
