Found on a website:
I searched google and found applications that rip DVD to AVI 2.0I found the following on a website:
You can use a codec which uses reference files like the Canopus DV codec (splits the file into smaller segments) even if you use FAT32, but a nicer solution is to use the newer AVI 2.0 codec and NTFS (which means Win2K or XP) and you will not see this limitation since both technologies do not have the 4GB filesize limit.
I can now capture an entire film (about 25GB) via Premiere 6 using the Microsoft DV codec (AVI 2.0) using WinXP
http://www.google.com/search?hl=en&lr=&ie=UTF-8&oe=UTF-8&safe=off&q=avi+2.0
But, I can't find it as a 'stand alone' codec like Divx or Xvid. Anyone know of this? Microsoft mentions it as well in their documents, but provide no more information as to how to download it.
Anyone has any information concerning this?
Other articles of interest concerning AVI 2.0
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/wcedshow/html/_dxce_d...extensions.asp
http://realforum.real.com/realforum/msg07620.html
Results 1 to 1 of 1
Dazzle dvc100 w studio 12 does it capture AVI 1 or AVI 2 or DV-AVI
By st711 in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 18:30 -
avs (avi to avi) ends up out of sync ... winavi output file too big
By mandy in forum Video ConversionReplies: 1Last Post: 21st Aug 2009, 06:56 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 16:38 -
ffmegX v0.09w and converting avi videos into avi.ff.avi videos
By paddymick in forum ffmpegX general discussionReplies: 2Last Post: 3rd Nov 2007, 00:10 -
How To Split Single DV AVI file into Multiple DV AVI files using Time Stamp
By insysnet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Aug 2007, 13:49
