After reading about the dye not making to the edge of crappy discs , I've done a little extra compression as to not bring the data all the way to the edge. I usually allow 200-300mb below the max which doesn't seem to affect movie quality. Any thoughts on this value? Too high?too low ?
I'm using ricohs,so is this even necessary??
GuestGuest
I tend to compress films to 4.2 gig for just the same reason..Even though i use Ritek Go4's. Never had a problem with playback even when filling the disk, just feel safer.
Not bothered by small problems...
Spend a night alone with a mosquito -
hmm - i think i might try this - i heard the same thing - i was using sandy yang and it was freezing at the end - i'll try compression an extra 200 mb and see if it stops - thanks
I had a sandy yang once, but I found a little antiseptic and a plaster worked wonders, even to the edge.
Sorry, I'm bored and couldn't resist it.
Does The Newer UDF Format Take Up More Disc Space?
By Arby in forum Newbie / General discussionsReplies: 12Last Post: 30th Jan 2012, 13:07 -
No space on disc to finalize
By Ordinary Joe2 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 6th Jan 2012, 09:54 -
The more space used on the disc,the less the quality of the videos it'll be
By DivXtacy in forum Newbie / General discussionsReplies: 4Last Post: 27th Apr 2009, 22:01 -
How to remove giant blank space at end of movie file?
By Quetzecotyl in forum EditingReplies: 2Last Post: 30th Jan 2009, 18:55 -
Is VCD/DVD disc space limited by time, or space?
By pingosimon in forum MacReplies: 6Last Post: 14th Jul 2007, 20:55
