I have a wintv go pci card for a couple of years now. I recently switched to windows xp pro and now I only get sound from the left speaker from my line in source. For everything else both speakers work, just the line in doesn't go through both speakers. I checked all my connections and they are connected good. I had sound in both speakers before when i had windows ME. Is this a driver issue? I am using the latest WDM drivers from hauppauge's site. I am using composite connections and the audio going directing into my sound card (Built in on mobo).
thanks
does anyone know how to fix this? I'm really desperate to fix it.
Try another source for line in to make sure its not a line in problem,if it still has only one side then go to control panel/sound and audio devices/audio and check both line in for record and playback properties and see if the balance is to one side.
Check your connections again...
Is the line-in jackplug making contact within the socket for both left and right channels?
My sound card's line-in sometimes fails on one channel and i always find it's the line-in plug not making contact within it's socket - the line-in plug is a very tight fit and presses against the plug in the adjacent socket on my sound card just enough sometimes to lose one channel's contact in the socket.
Martin. -
Thanks for the help. I figured out what it was. The line in jack was pushed all the way in to make sure it was a tight fit but when i pulled half of the tip out then I had sound from both speakers. That's wierd I guess it was just pushed in too far but I dunno why though I didn't force it. So As long as I have it pulled out a little bit it seems to work. thanks
Sounds like a cheap plug.
3.5mm stereo patch leads and plugs can be a varied mix of quality and sub-standard parts.
I'd bet that a decent quality replacement wouldn't need to be 'semi-inserted' into your line-in - no need for a bodge job!
Martin.
DVD-R sound coming through only one speaker
By Marshfish in forum Newbie / General discussionsReplies: 5Last Post: 7th Sep 2011, 02:40 -
Edited sound jumps from speaker to speaker
By len hend in forum AudioReplies: 3Last Post: 23rd Jul 2010, 06:49 -
Help: Sound only plays from left speaker
By rdc in forum AudioReplies: 5Last Post: 31st Dec 2007, 22:25 -
how to remove the black line to the left
By Cazz in forum Newbie / General discussionsReplies: 0Last Post: 27th Dec 2007, 07:55 -
Audio coming from center speaker help
By faramith in forum AudioReplies: 6Last Post: 19th May 2007, 23:15
