    Feb 2004
    Brazil
    Could some body help me to find the way to put vobs from different sources keeping all audio traks (english, portugues etc..) and all Subtitles? Up to know I only find the way to do that join the vobs with VobEdit, Fixing the subs and creating a VTS_01.ifo with IfoEdit. It works fine in my pc and on DVD player Standalone, but to look more professional job I would like to include a MENU!
    Osmar
    Osmar
  2. Check out the AUTHORING guides to the left. There are a few there that explain how to author with multiple audio, and the tools they use also allow for creating menus.
    Feb 2004
    Brazil
    Thanks for your help. May you can help me to go ahead a litle bit?
    I did author a multiple title VTS using the DVDLab and finally IfoEdit with reasonable success following the guides from this site . It has 10 different titles, all with one subtitle and 2 audio streams (LPCM and AC-3) Testing the DVD in my DVD set (standalone) it works fine, I can select the subtitle and audio on remote control normally. In order to improve my DVD I'd like to reauthor it including a Audio and Subtitle MENU. There is a guide in this site " Guide to Multiple Audio with DVD Lab" that can be used to select audio for different languages, than I think that is possible to do some think similar to select subtitles and audio (LPCM , AC#, DTS ).I also think that the hard work will be on IFOEDIT, once the DVD Lab is very interctive tool.
    Fernandes
    Osmar
