  1. I'm using Sony DVD Architech 1.0 to cerate a DVD for our church. The file size is 5.3 GB. My DVD's will hold 4.7GB. Is there any way to get the file to fit. Open to suggestions.
    Apr 2002
    The State of Frustration
    You can reduce the file size by lowering the bit rate. Use the BitCalc program in the Tools section at left to discern how much it should be lowered.
    Hello.
    Jan 2004
    Helsingborg,Sweden
    You can Use DVD2ONE it is very easy and it makes it so big it can be....VERY EASY!!!
    ________
    ________
    ________LOL?
  4. All you have to do is to play with the bitrate, no need for any program to split this into 2 dvd's....the difference is way to small to do this.
    Have fun...
  5. Member sacajaweeda's Avatar
    Sep 2003
    Would I lie?
    Two schools of thought on this. You can either shrink it to fit with something like DVD Shrink or you can do it the right way and just encode it with the proper bit rate. Me personally I don't believe in or recommend the shrinking technique. I'm a believer in doing it right.
    "There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
  6. Author what you have, but before burning, run it through DVDShrink, then burn the DVD.
