Just got it yesterday, upgraded the firmware, and have noticed a few things which perplex me.....
1. I'm new to this, but I guess I can delete tracks on a DVD+R disk? I thought once they were burned on that was it.....I guess I was wrong.
2. I'm trying to finalize +R disks that were made on a different recorder and keep being told there is something wrong with the data on the disk, to press OK to open the tray, but the instructions in the manual say to run through a procedure in the setup menu that doesn't exist.
3. I played a finalized +R disk yesterday prior to upgrading the firmware, then after doing the upgrade that particular disk gives me a DISK ERROR message and will not play.
4. Finalized -R disks are just spit right back out when attempted to be loaded.
Anyone else have any related issues?
Thanks!
Originally Posted by chopsuiPinnacle Studio 8 and DV home video editing (ver.9 already home)
Finalizing a disk made in a different recorder is problematic, in that each manufacturer has proprietary technology in their machine.
Phillips can only finalize a disk made in a Phillips, and so forth.
I am curious...How do you upgrade firmware in a stand alone desktop DVD recorder?
Given that it's not working so well, since you did that....I don't know I want to try it, until you work out the bugs.
The other disks you mentioned, particularly -R, are not compatible with newer machines, acccording to Phillips tech support...I had the same issue.
Good luck. -
Andy. -
like asichter, my 75 will play -R's recorded from a Panny (E50 i think) no problem.
Why did you upgrade the f/ware, was the problem there before?
I'm a big advocate of the "if it ain't broke, don't fix it" philosophy. If the machine does all you need, then why upgrade f/ware......do it if you need it, but remember, there's always a risk associated with firmware upgrades.
Can you downgrade back to the original firmware?
davestalker, instructions on how to upgrade on a Philips standalone is on their web site (you need to create an upgrade CD with your PC burner)
Cheers
Nezza -
I have since returned the Philips DVDR75, but I did get a chance to test some of my older no-name brand -R discs recorded on the Panny E20 They all played fine except for one shich I had put a label on. It froze every now & then from about half way through. The same disc though played fine on the Panny E20, E50, S35 & my Teac player. Could have had something to do with the label.
Andy.
Can Philips 5990 firmware be used on Philips 5992 Dvd Player
By peggypwr1 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2010, 16:06 -
Any Vancouver Olympic observations? 1080i 29.97 sure helps here vs 25.
By edDV in forum Newbie / General discussionsReplies: 6Last Post: 28th Feb 2010, 18:57 -
avchd m2ts/mts editing stats and observations.. and some questions linger..
By markm75 in forum Authoring (Blu-ray)Replies: 8Last Post: 23rd Jul 2008, 23:02 -
Philips DVDR75 overwriting existing titles
By Rletson in forum DVD & Blu-ray RecordersReplies: 4Last Post: 5th Dec 2007, 17:38 -
Philips DVDR75 worth?
By stantheman1976 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 2nd Jun 2007, 11:48
