Does anyone have an opinion on lens filters? i.e. UV, etc. I was wondering if they are worth the money, will they make my videos look any better? Thanks!
Just for the reason a $20 lens filter will protect the camera lens from getting accidentally scratched is worth it on it's own. Replacing a lens filter is a lot better than having to get your camera lens replaced, which would cost you big $$$.
putting a UV filter on my camera is the absolute first thing I do when I haul my new camera out of the packaging for the reasons given above.
What they said. A UV filter is the cheapest insurance you can buy. Less then $10.00 at a local photo/video shop for a 37mm.
As for all of the other filters, it's a toss up. If you know for sure that you want an effect then a filter may be the way to go, you don't have to spend the time adding it in your NLE and waiting for it to render. However if later you don't like it you have to either live with it or re-shoot the video. But Tiffin and others have some real nice filters. I keep a set of Polarizers in my kit because it will remove glare that you can't do in editing. If you put one on top of another you can "dial in" a "ND filter effect" by turning one to adjust the amount of light blocked. Star filters are also something that is easier to do with a filter. But once you do it your stuck with it.
Haali Media Splitter, LAV Filters, AV Splitter...How do these filters work?
By Moontrash in forum Software PlayingReplies: 3Last Post: 25th Feb 2012, 19:00 -
High Definition Lens Filters
By videobread in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 17th Feb 2012, 16:27 -
Lens Help?
By MurbeckJackson in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 30th Jan 2011, 17:41 -
Camera or Lens?
By andy33 in forum Newbie / General discussionsReplies: 4Last Post: 28th Mar 2010, 21:55 -
[Solved] Question about MPlayer filters in FFDShow and Mencoder filters
By BlooderButcher in forum Video ConversionReplies: 4Last Post: 24th Nov 2008, 12:32
