  1. Got a Mpeg file 800 meg and need to re encode this movie so I can authorize it to DVD coz it pop up a error in authorizer resolution blah blah not a valid DVD file OK
    now the problem
    open it in TMPGEnc and the famous bullshit error comes up "File Unsupported"
    now I have a Xvid codec and a DIVx codec this is a MPEG anyway so i guess I'm screwed and download this for no reason......
  2. Just another note I read the guide it says press ignore if that error comes up but ignore is grayed out so i can't
  3. does virtualdub open it ?
    If so frameserve to tmpgenc.
    If it's wet, drink it
    My DVD Collection
  4. Can you play this file with media player?
    Do you know if it is MPEG1 or MPEG2?
    My guess is that if you can't play the file you don't have a MPEG2 codec (DivX etc are MPEG4 so will not work). There are ways round this. If you have a s/w DVD Player (maybe came with the drive) install it. If you can play the file you should be able to open it with TMPGEnc.
  5. Ive got TMPGE Plus Virtual Dub didn't open it but Virtual dub SVCD did
    it's a MPEG 2 file but the problem is DVD authorizer will not let me do it i need to re encode it so I take it TMPGEnc frameserver is different?
  6. Originally Posted by tim6661234
    I can play the file fine
  7. Thanks guys thanks for your help it looks like the newer version of TMPGEnc works!!! and opens it the old one didn't
    thanks
