hi all...
first post here....
burning an mpeg onto a normal cd (as a vcd) seems 2 b a simple affair.... can u simply burn several mpeg files onto 1 dvd disc, so that they play as vcds????
cheers!!!!!
cte
1 dvd player i have can actually play mpeg files from a dvd. but the mpegs have to be dvd compliant. also, most dvd players won't play a dvd with just mpegs on them. you would be better off just authoring the disc properly with a program like dvd workshop. so it will work on almost all dvd players.
As long as they are dvd compliant resolution you can load them into tmpgenc dvd author and it will do the rest.
https://www.videohelp.com/vcd
edit:
I just realized that this chart I've been referencing doesn't have the audio sample rates listed.
(doh!)"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
Audio has to be 48k(DVD). You'll have to convert it and up sample it from 44k(VCD).
There are guides on this site on how to make DVD-VCD.
Author VCD files in a to DVD Disc
By akakiami in forum Authoring (DVD)Replies: 6Last Post: 5th Jan 2009, 06:22 -
Help:How to author 3 disc vcd movie into single dvd without reencoding
By devstallion in forum Authoring (DVD)Replies: 6Last Post: 31st Dec 2007, 04:40 -
Copying,Copied DVD-Rw disc to,DVD-R disc
By 306james in forum DVD RippingReplies: 3Last Post: 12th Nov 2007, 12:45 -
Is it possible to rip a HD DVD disc to Hard Disc ?
By fjmr in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2007, 13:50 -
Is VCD/DVD disc space limited by time, or space?
By pingosimon in forum MacReplies: 6Last Post: 14th Jul 2007, 20:55
