Using Vegas 4.0 to capture via a firewire, I've just tried capturing a BetaSP video source, passed through my Sony DCR-TRV38. Using this procedure I've noticed no drop frames, however the audio captured was only 32000 Khz/16 bit stereo. I've scoured the Sony handycam manual and there is no way I can see to change this sample rate to 16bit stereo, 48000 Khz.
Does anyone have any suggestions on how I can even capture at 48000Khz/16bit stereo?
Darren
Somewhere in the camcorder menu you should find an audio option to set either 12 bit or 16 bit PCM. Set it to 16 bit and try again.
Richard, thanks so much. I found it and it captures at 16bit/48000Khz.
Very relieved and happy,
Darren
how to change frame rate on staxrip?
By VistaXP in forum Video ConversionReplies: 6Last Post: 6th Apr 2011, 15:13 -
How to change sample rate in FFMPEG
By MackanZoor in forum AudioReplies: 5Last Post: 24th Jan 2011, 14:31 -
Help with understanding when to change frame rate
By mlaran in forum Video ConversionReplies: 3Last Post: 22nd Feb 2010, 11:11 -
Change FPS Rate/Scale ratio
By newpath in forum Video ConversionReplies: 4Last Post: 20th Nov 2008, 09:01 -
CCE keeps on trying to change my frame rate?
By friedtofublocks in forum Video ConversionReplies: 17Last Post: 14th Dec 2007, 06:21
