Can anyone help. Recently purchased a DVDR75 but am having problem actually getting a picture on the TV through Scart. Sound is coming through but no picture. Can anyone suggest the correct connections for the following.
Sky + box - TV and AUX scart sockets
TV - EXT1 and EXT2 scart sockets
DVD - TV and AUX scart sockets
I have tried S-Video but know very little about it and got fed up trying to get it to work.
Could it possibly be a scart lead problem, even though I have tried various ones.
Any help much appreciated.
If you're getting sound, then you should be getting a picture too.
I'd double/treble check your scart leads, particulalrly how securly they are pushed in.
Mine has a tendency to move enough to drop the audio when I push the unit back into position on it's shelf.
Otherwise, I'd suspect the scart lead itself
Nezza -
You need to connect the DVDR75 from EXT1 straight to your TV EXT 1.
Then SKY Box into the DVDR75 on EXT2
Check that the pins on the scart leads have not been pushed back a little this can happen.
If all else fails can you just try it on a different TV. The connections on TV sockets can become loose its quite a common problem. -
Make sure you use the TV Scart output from the Sky Box in order to get RGB into the DVDR75 (Ext2).
Also, make sure your DVDR75 isn't set up for S-Video in on EXT2. Look at page 68/69 in the manual under User Preferences for info. (Picture Settings>Scart Video) -
Return this Philips and get the Panasonic E80H. I had nothing but problems with this unit. Maybe other people had better luck with there's.
Good Luck
Philips 3455dvdr stays on philips logo
By vbdanl in forum DVD & Blu-ray RecordersReplies: 7Last Post: 14th Sep 2010, 11:15 -
Philips DVP2320
By piber in forum DVD & Blu-ray PlayersReplies: 0Last Post: 7th Jun 2010, 08:56 -
Can Philips 5990 firmware be used on Philips 5992 Dvd Player
By peggypwr1 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2010, 17:06 -
Philips DVDR75 overwriting existing titles
By Rletson in forum DVD & Blu-ray RecordersReplies: 4Last Post: 5th Dec 2007, 18:38 -
Philips DVDR75 worth?
By stantheman1976 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 2nd Jun 2007, 12:48
