Hi,
I keep reading the tips that pop up when launching DVD Lab, and find them to be useful for the most part.
But I can't seem to find out how to do one thing I need. How does one create a DVD in DVD Lab that begins to play when inserted into a player. No menu, with no buttons, just have it play when inserted.
In the start up tips, DVD Lab mentions that this is a possibility, and a menu need not be used. But I find nothing in the manual about this type of authoring.
Thanks in advance,
Jeff
You're kidding, right?
Import your file into the project. Drop your mpeg2 movie file onto the "first Play" icon. Delete the menu icon. Compile.I don't have a bad attitude...
Life has a bad attitude! -
If you are using version 1.4beta1, when the startup wizard shows, select "movie only".
if using an older version, see post above. -
No, I am afraid I am not kidding. I just did what you suggested and nothing happened.Originally Posted by leebo
The mpeg2 file is to be dropped into the movie 1 area is it not? When it is dropped over the first play (green) icon, nothing happens. Is the "first play" icon you are referring to the green button in the connections area?
Please give me a bit more info on this someone. I have a paid job to turn in, and it came out really nice. I just don't want a menu in this one.
Jeff -
Yes. The mpeg2 file is to be dropped into movie 1 area. After that, just go to the "connections" window, and choose the "Draw links" (it's the first "+" sign under the "arrow" sign) and draw a line from green button to your movie 1.Originally Posted by hiptune
As for what will happen when the movie ends?
You have 2 choices:
1. don't do anything. it will just stop.
2. draw another line from the end of movie button to the movie itself. In this case, you are creating a "loop". So the movie is going to play forever. -
Sorry, odyssius98 is correct. But that is on the help page, no?
Guide for extracting menus for editing, and reinserting edited menus
By manono in forum Authoring (DVD)Replies: 167Last Post: 8th Dec 2022, 03:44 -
DVD Lab Pro 1.6: Links in menus get blue under fresh Windows installation
By Paker in forum Authoring (DVD)Replies: 4Last Post: 2nd Jun 2011, 13:54 -
Can u use PSD files for menus in DVD LAB PRO?
By Cygnus111 in forum Authoring (DVD)Replies: 2Last Post: 12th Dec 2010, 16:02 -
Cell Menus Dvd lab pro
By angelus214 in forum Authoring (DVD)Replies: 2Last Post: 8th Oct 2008, 10:52 -
multi menus (in DVD LAB PRO 2) with different formats/Button issues
By dblue in forum Newbie / General discussionsReplies: 11Last Post: 18th Oct 2007, 19:10
