  1. Hi
    I have a problem that I haven't found an answer so far.
    I have DVDs with 2 audio streams (Karaoke or movie with 2 languages) but don't have menus and chapters. I want to create menus for those DVDs.
    I use DVD-Lab which is a great software but it doesn't support multiple audios streams.
    I followed the instructions found on this site with IfoEdit and back to DVDLab but the problem is that IfoEdit will split automatically my files into smaller files and when DVDLab starts, I'll have to join them back together and it won't help
    Anyone can plz help me on this ?
    Thank you
  2. There are two guides for this in the guides section, but basically you can do multiple streams with DVD Lab already using the built in ifoeditor to select multiple audio steams after compilation.
