Dear Friends,
Here’s the long and the short of it. I want to be able to transfer some older family VHS & 8mm tapes to DVD. I also want to be able to copy some DVD movies to DVD. I gather from questions that I’ve asked that the best way to do that is to copy these mediums to my Hard Drive and then transfer them to a DVD disk. What I believe I need (and you can help me with this) is a DVD +- Burner, something that will enable me to connect my VCR to my computer, and software that will enable me to edit & enhance my VHS tapes and in some cases compress my DVD’s so they will fit on a regular DVD disk without loosing quality (and if you have suggestions on which disks work best, that too). I’m a poor working stiff so I want the highest quality for the lowest price. If you guys (and girls) have some ideas, some names, and or some prices (and maybe where to purchase) I’d really appreciate them. How to’s will help as well. Whatever you can give me I’ll take. If it helps, looking at my systems properties it says that I have a AMD Anthlon™ XP 1800+ (processor), 256 megs of RAM, I use Windows 98SE, and have about 33 gigs (of 60 gig) available on my Hard Drive, a 3D fx Voodoo Banshee Display Driver, and I don’t know what else. Anyone who has equipment similar to mine and has had success at doing the things I want to do please advise me as to what you used. Anything you can tell me will be appreciated. Thanks in advance you guys (and gals) have been most helpful in the past.
Thanks & God Bless
Uncle Bob
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator BJ_M you posted this like 5 or 6 times and even after some threads were closed and you were warned
Closed Thread
Results 1 to 1 of 1
Uncle Bob
Interesting update for D-VHS decks on JVC site? & HM-DH4000U on sale at B&H
By OldMedia in forum RestorationReplies: 3Last Post: 4th Jun 2010, 23:20 -
Capture AT&T (ATT) Uverse video signal & AT&T Uverse DVR programs
By bluehan2010 in forum Capturing and VCRReplies: 1Last Post: 23rd Apr 2010, 11:40
