I am getting a Philips DVD727 next week and am wondering about something. It says it will play VCD, SVCD 1.X and 2.0 version on each. I also read somewhere that it will play mpeg data cds. Does that mean if i want to record at higher that vcd but not in the format of svcd ( not 480-480, or also some of the higher audio and motion things ) it will play. If not can someone explain this.
Bob
what it means i think is it will paly mpegs off the disc, mine (crown dvd 550) will play mpegs off a cd with no (s)vcd) formatting ie the folders etc, so its just the raw mpeg on a cd, burned as a data disc, its played everything ive thrown at it, with some files being nowhere near the normal standard compliance needed for svcdso technicaly theyd prob be xvcd's if i authored them as vcds, but the reason i dont do this very often is if i want to share the cds with family or friends they may not be able to use them on theyre players,
Originally Posted by §kipTracer65
That's what i was hoping. 2 more things, if i record in a widescreen 480x240 will it play as a raw cd like you said? Also how do i get the audio setting right, now i have them set for the best sound on my computer, but will they sound the same on tv (not sound but volume, i dont want o turn the volume all the way up and then go back to my tv cable signal and have ear splitting sound.
most of the time ive done this was with mpeg's i downloaded, and never bothered to check the bit rates, just put them on a cdrw to watch and bin cuz i was to lazy to try and author properly, but ive never had a problem, ie it played as it would on a pc, now when i saw it played ne thing, i mean with in reason,(the bit rate wasnt 10000 for example) ive even tested it using a single .vob file off a dvd that was small enough for a cd, but i coulnd fast forward it i played though, not that it was very usful to know that had to much time on my hands i guess lol
That's good, thanks. i am glad it works like that. When i get it i will let you know how it goes.
Help burning and playing VCD
By NLO_Cliff in forum Authoring (VCD/SVCD)Replies: 12Last Post: 16th May 2011, 09:55 -
Burning TS file to DVD and playing in a Blu-Ray player
By robertazimmerman in forum Authoring (Blu-ray)Replies: 4Last Post: 9th Nov 2010, 12:04 -
Burning DVD using ConvertXtoDVD - rating problem when playing?
By mistyfog in forum Newbie / General discussionsReplies: 1Last Post: 20th Jun 2009, 10:28 -
Question about playing videos on my TV
By cb220 in forum Newbie / General discussionsReplies: 13Last Post: 6th May 2009, 07:48 -
converting, burning, and playing avi files
By unionman4077 in forum Video ConversionReplies: 1Last Post: 27th Feb 2008, 17:01
