I am very masterful on my pc, but when it comes to burning movie files to DVD-R, not one program will do it for me. I have files (.vob, .mpeg, .wav, .etc) that no program will author to a DVD-R (TMPGENc, DVDit!, MyDVD, Ulead, ETC...)...
every files with every program either has numerous errors, or crashes my system...(pc/900mhz,40GBHD, 333RAM)
What gives? I want to go VOB>AVI>DVD...and I have spent weeks trying.
Any help please?
To make a DVD from VOB files I use:
Tmpgenc DVD Author and create DVD Folder
DVD Shrink if this folder is too big to fit a DVD
Burn with my burning software as data.
Very simple.
For >vob>AVI>DVD... then open the vob file in VirtualDub MPEG2 and frameserve to Tmpgenc encoder. Use DVD Author to create the folder then burn it as data.
Good luck. -
I sometimes have these problems. Ok, a lot of the time I have these problems. But work on it long enough, and you evertually find your solution to your problems. I once couldn't make any backups for a good couple of months because I found out DVD Decrypter was copying in the wrong "mode".
Stupid Flanders with his stupid iLoHD04 problems!
By Batchman in forum DVD & Blu-ray RecordersReplies: 33Last Post: 4th Mar 2011, 17:41 -
i know this sounds stupid but...
By cthuggha in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 30th May 2009, 09:02 -
Avidemux .. I must be stupid
By bvdd in forum Newbie / General discussionsReplies: 9Last Post: 1st Mar 2009, 17:06 -
Probably a stupid question, BUT...
By HmNtr in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 7th Dec 2008, 12:22 -
New to burning: Am I stupid?
By Eat Right in forum Newbie / General discussionsReplies: 1Last Post: 8th Jun 2008, 12:47
