How can I create subtitles and then be able to turn the subtitle off when I am viewing the svcd?
Hi :
You ´ll need to use or I-Author or Philips SVCD Designer.
They are the only that can do a OGT (subtitle) encoding.
And the one full compliant with SVCD specs is Philips SVCD Designer.Some standalone and software DVD players don´t work very well with movies subtitled using I-Author (subtitles aren´t funcional).
More bad news : both softwares are hard to find , only in some "dark" web site you can reach it.Worst than , legal licensing or not so legal are difficult to do.
Try http://www.google.com to search using software´s names.
At last , Philips works only in WIndows NT ,not 9x,not 2k.
Good Luck !
<font size=-1>[ This Message was edited by: alb1n0 on 2001-10-22 10:51:48 ]</font> -
ok
I have i-author. but when I have created a subtitle on a movie and viewing it on my standalone dvdplayer, is it possible to turn the subtitle off then?
Alternate download locations
By teamsleep in forum ffmpegX general discussionReplies: 7Last Post: 22nd Apr 2012, 05:24 -
By MGadAllah in forum LinuxReplies: 1Last Post: 6th Nov 2011, 02:17 -
Free AMCAP Alternate?
By Mickz in forum Capturing and VCRReplies: 8Last Post: 4th Aug 2011, 21:13 -
Alternate format other than DV.
By cowmix in forum Capturing and VCRReplies: 13Last Post: 14th Sep 2009, 23:21 -
lossless conversion to alternate containers
By krohm in forum Video ConversionReplies: 33Last Post: 12th Jun 2009, 04:19
