Wondering if anyone could help me out -- I would like to have audio playing underneath a menu, but I don't want that particular piece of audio to stop or restart when I choose another menu. I would like it to play continuously across different menus. Example, main menu leads to a sub-menu, sub-menu one leads to sub-menu two and so on. I would like the song to play continuously as the viewer navigates through the menus. Does anyone have a solution to this scenario? Hope to hear from someone,
Andrew.
What you ask to do cannot be accomplished staraitfowardly using the DVD spec. This is because you may not keep audio as you change menus
Each menu must posses its own clip should you want audio to accompany it...This is the DVD spec.
That said, many workarounds exist
Most involve the use of seamless (inaudible hopefully) crossfading between the menu items and the use of DUMMY PGC's to trigger a believable sequence.
A more professional application than Adobe Encore will contain a series of Numbered GPRMS that enable the sequence of the DVD playback to be entered into the player's memory to avoid an 'incredible' audio sequence to play back
Adobe Encore Blu-Ray audio out of sync
By MindController in forum Authoring (Blu-ray)Replies: 1Last Post: 21st Aug 2012, 04:12 -
Continuous audio throughout menus
By dth122 in forum Authoring (DVD)Replies: 3Last Post: 14th Dec 2009, 23:34 -
Normalize audio in Adobe Encore CS3?
By Benhermies in forum Authoring (DVD)Replies: 3Last Post: 31st Aug 2008, 03:11 -
By Benhermies in forum Newbie / General discussionsReplies: 1Last Post: 29th Aug 2008, 13:40 -
Adobe Encore DVD keeps on conforming audio
By geohei in forum Authoring (DVD)Replies: 1Last Post: 27th Jun 2007, 09:49
