I've made countless VCD's with TMPGEnc and know the program pretty well. However, picture quality with cartoons seem especially difficult.
Recommended settings?
There's nothing you can really do I'm afraid, especially if the cartoons are from VHS. MPEG seems to have a problem with large areas of flat color that are prevalent in animation, and if they're from VHS then the problem will be even worse because even the best noise reduction filter can't remove everything.
Try using the smoothing filter set to just short of maximum settings. This can do wonders for cartoons.
You can also try the CG quantize matrix (instead of standard you choose the one optimized for computer graphics and animation). Enable soften block noise and the noise filter. Use highest motion estimation quality.
Or you may want to try Canopus Procoder. It can make very soft and clean Video CD encodings. TMPGEnc can make a sharper picture but it also has more block noise artifacts.Ronny
Any recommended settings for TMPGencXpress color filter?
By Anonymous5394 in forum Newbie / General discussionsReplies: 0Last Post: 27th Mar 2010, 12:29 -
HDTV capture using Hauppauge 1212 - recommended settings?
By JamesNG in forum DVB / IPTVReplies: 0Last Post: 30th Dec 2008, 10:13 -
FLV to Avi or MPG, recommended settings?
By dzoni in forum Video ConversionReplies: 1Last Post: 12th Sep 2008, 16:27 -
Recommended Min Quality Video settings for CamStudio
By Firewire60 in forum Video ConversionReplies: 0Last Post: 22nd Feb 2008, 08:11 -
Recommended settings for dvd to divx ?
By jimcgr in forum DVD RippingReplies: 6Last Post: 11th Feb 2008, 08:25
