I am new to capturing world. I have a KW878RF PCI card and I try capture my home movies of my 8mm video camara with virtualdub and this generate files with extension .avi very large for little minutes (350MB for 2:30min). Is this correct ??? I need to capture movies of 1 hr. or more and I donīt have many disk space (only 8GB). Is there any option for generate small files ?
Excuse my bad english.
Rudy.![]()
You need to set the compression.
High Quality Capturing with Little Frame Loss in VirtualDubRegards,
Rob -
you should also get another hard drive seperatly for your captures. the drive you have is really not big enough for even compressed avi captures,
Donadagohvi (Cherokee for "Until we meet again") -
If you want to get serious about video capturing, you're definitelly going to need another hard drive. Drive prices are falling steadily (I bought a 120Gb here in Canada for under $150, taxes, shipping included). You need space to capture the raw file, then space for the mpg file(s) that you'll have to create for your disc, then space to compile your discs to. 8Gb definitelly isn't gonna cut it.
you can buy a 160gb Maxtor hardrive at STAPLES for $139.00 with a mail in rebate for $30
And let's not forget that a Celeron processor will hold up encoding too...
Regards,
Rob
MPG files are too large
By sldvd in forum Video ConversionReplies: 2Last Post: 6th Mar 2011, 06:59 -
Copying Large Files
By persephone in forum ComputerReplies: 14Last Post: 13th Dec 2010, 04:23 -
video files are to large!!!!!!!!!!
By sharmine in forum Newbie / General discussionsReplies: 3Last Post: 5th Jan 2008, 07:30 -
ImgTool Files Too Large
By opieandy in forum Authoring (DVD)Replies: 4Last Post: 27th Sep 2007, 22:08 -
Dr. DivX converts large VOB files into tiny unusable divX files
By texas1 in forum Newbie / General discussionsReplies: 2Last Post: 6th Aug 2007, 22:44
