I am capturing using an ADVC50, but how do I get the resultant file to be opened by Virtual dub for editing/cleaning up/ cropping etc?
Suggestions appreciated.
You need to install a DV codec (check the tools section). Then you'll be able to open either but you'll only be able to use the audio if you're file is Type2 DV.
Panasonic DV Codec is a Type 2, and will let you load DV into VDub.
Its in the Tools section.
There is also a DV-Converter in the Tools section. It converts Type 1 DV to Type 2.
Can't edit MP4 files in Virtual Dub
By brevardo in forum EditingReplies: 25Last Post: 10th Mar 2011, 21:18 -
Virtual Dub editing MP4 and WMV files with new plugin
By brevardo in forum EditingReplies: 5Last Post: 14th Jan 2011, 12:26 -
Editing and syncronising text in virtual dub
By santolina in forum EditingReplies: 4Last Post: 23rd Jul 2009, 18:29 -
DV1 versus DV2
By SCDVD in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 18Last Post: 23rd Feb 2009, 05:18 -
Virtual Dub 1.8.5 Editing question
By zenzen1 in forum EditingReplies: 3Last Post: 27th Sep 2008, 05:55
