I have found another way to cure frame drops even though it probably has been mentioned before.
I recently bought a Canopus ADVC50 but had jerky video and sound drop outs.
Canopus advised me to substitute another VCR in a process of elimination, and the problem was gone.
Trouble is the VCR I use for capture is a new JVC with S video output which I bought particularly for this project.
So I looked at the various functions in the JVC's set up. One of them was "video stabilizer".
I went searching for such things because I had solved frame drops before by turning off auto tracking and controlling it manually.
As soon as the "video stabilizer" was turned off the problems with the ADVC50 appeared to be gone (I am still testing).
I went back to capturing full resolution avi in virtual dub (where I had been dropping frames) and there were no frames being dropped there either. During caputure I turned "video stabilizer" back on and presto: frames dropping all over the place.
Turned "video stabilizer" off again and no frames dropped.
In fact the caputure is now so stable I may not need the ADVC50!
But it is nice knowing the audio is locked to the video, all I have to do now is work out how to edit the DV files made by the ADVC50 within Virtual dub.
Any good ways to do this? I prefer not to use TMPGENC as I create 4000kbps MPG2 files and TMPGENC makes them look blocky,especially if there is fast movement in the video.
Here's a funny VCR switch story...
https://www.videohelp.com/forum/viewtopic.php?t=194275&highlight= -
From the downloadable user manual for my JVC HR-S9500U S-VHS VCR.
"By activating the Video Stabilizer you can correct vertical
vibrations in the picture when playing back unstable EP
recordings that were made on another VCR. When this function
is set to "ON", vertical vibration will be automatically corrected.
*The default setting is "OFF".
The Video Stabilizer is only for viewing poor quality EP recordings. You shouldn't have that setting turned on at any other time.
Solving the mystery of the 2 year old DVD-Rs
By persephoneflower in forum Newbie / General discussionsReplies: 21Last Post: 8th Apr 2012, 06:45 -
AverMedia HD DVR - Frame drops in live playback
By Anonanon in forum Capturing and VCRReplies: 3Last Post: 1st Mar 2012, 02:11 -
Joining 2 TS streams produce glitch and frame drops
By arminio in forum DVB / IPTVReplies: 8Last Post: 7th Jun 2011, 03:30 -
need help solving excess memory usage in video capture
By philfr in forum Newbie / General discussionsReplies: 6Last Post: 10th Jan 2011, 19:47 -
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 17:26
