Hi gentlemen,
I am so desperated before I post this question for help. I own quite a large number of karaoke dvd. Each dvd only has 1 or 2 songs I used to use. It is so inconvinient to take a whole stack of dvd when we have karaoke party elsewhere beside of my house. I want to rip all of my favorit songs and store them on my laptop. All I need later is taking my laptop and connect it to a stereo system and a TV also playing the karaoke songs via a karaoke software. On most of the karaoke dvd I found .vob type of file. How can I rip these file to harddrive and still be able to play them back as a karaoke song (i.e be able to turn the vocal on and off)?
Thanks in advance
Thang
ps. There are many people out there has the same wisdom but I don't think anyone found the answer yet!
Rip the entire dvd to your hd,
http://www.dvd-guides.com/guides.php?category=dvdrip&name=decryptervob
Play the dvd with PowerDVD, by select open dvd file on hd and open the video_ts.ifo file. -
You can use DVD-Shrink to rip selected songs from your DVD disks. Use the Authoring function, then user Start/End to select the specific song you want to extract. Put each song on a separate folder on your hard-disk because the program always creates the same DVD structure folders and files.
Hope that this will help. -
Sorry folk, I did try many software such as smart stripper, dvd shrink, DVD decrypter but I can not find the way to turn the vocal on/off yet. If you can come up with the solution I think you have a lot of people. Thank you.
store bought dvd won't play in laptop or pc, can't copy
By ghola in forum DVD RippingReplies: 11Last Post: 8th Mar 2012, 17:17 -
Ripping dual audio tracks Karaoke DVD
By Longhorn1955 in forum Newbie / General discussionsReplies: 3Last Post: 8th Dec 2011, 00:14 -
Can anyone advise me how to copy karaoke dvd songs
By BILLION in forum Authoring (DVD)Replies: 1Last Post: 8th Aug 2010, 18:02 -
MIDI DVD Karaoke Player 40,000 Songs with High Definition TV out, DIVX, USB
By Manokat in forum DVD & Blu-ray PlayersReplies: 1Last Post: 19th Jun 2007, 05:26 -
vocals on karaoke songs recorded on both channels using TDA?
By edong in forum Authoring (DVD)Replies: 0Last Post: 9th May 2007, 13:19
