Does anybody know what software is ripping or creating 492 & 542 KBPS MP3's? Is this all hardware based(sound card) or is there a software?
Those are variable bitrate (VBR) mp3s. The highest bitrate allowable for mp3 is 320 if I'm not mistaken. Whatever you're using to determine the bitrate is giving you false results.
I recommend using Exact Audio Copy (secure mode) coupled with Lame Encoder (3.92x) using "--r3mix" settings for best VBR results.
WinX DVD Ripper Platinum Ripping at Wrong Bitrate
By wperry1 in forum DVD RippingReplies: 14Last Post: 15th May 2015, 14:05 -
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 08:38 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 19:17 -
Most compatible codec, Lossless bitrate, and max bitrate
By sevenlayercookie in forum Video ConversionReplies: 2Last Post: 6th May 2009, 21:43 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 8th Nov 2008, 00:54
