I am trying to burn the highest % compatible DVDs. PCM-WAV audio uses up too much space. MPEG audio is not 100% compatible. The AC3 audio from Besweet is said to not be fully compatible. TMPG Author with AC3 needs to have my computer on the internet for continuos vavlidation and I am off the grid at home and no phone line. So, what is an affordable way to make 100% compatible AC3 files? I wish there was a page on the net that listed how people are burning with what softwares and the compatability of various solutions and level of expertise. I have tried Roxio--lousy, TMPG Author--a little clunky but not enough variables and choices, TMPGplus encoding--EXCELENT, DVDit--low compatability, and am trying DVD-lab--promising but I want more choices.
DVDit defaults to Joliet ISO9660... I am wondering if this is causing some of my compatability problems? Is UDF the only way to burn? Sorry, I have not learned these issues yet.
Is a fail safe way to burn just burning the DVD volume, or is burning ISO images better?
Thanks to all for you help.
Glenn Woiler
Ulead's new Disc Creator 3 product does AC3 for $99 ($69 as an upgrade).
Leave it to Dolby to corner the market. Since MPG2 isn't a standard in the NTSC market, you're left with AC3 (which to do properly, you have to buy a program which has to pay licencing fees to Dolby) or use uncompressed PCM audio.
I use ffmpggui and haven't had any problems. Since I have no intentions of buying a Pioneer player, and every other player i've tried plays then fine, i'm not too worried about compatability. -
It allows AC3 import, not encoding.
Originally Posted by MrMungus-----------------------------------------------------
There is a reason why God gave us one mouth and two ears!!! -
Are you sure? I'm looking at this: http://www.ulead.com/dmf/compare.htmOriginally Posted by awlchu
In the "capture/import/encode" section. -
oh, you're right! my bad!-----------------------------------------------------
On the fly software AC3 encoding
By djdynamite123 in forum AudioReplies: 12Last Post: 24th Jul 2011, 17:35 -
Encoding AC3 to WMA Without losing 5.1 Surround (please help)
By RabidSmurf in forum Video ConversionReplies: 4Last Post: 2nd Mar 2009, 15:03 -
Arbitrary AC3 Re-Encoding by DVDStyler
By cyberboy in forum Authoring (DVD)Replies: 1Last Post: 6th Sep 2008, 16:57 -
No Audio when encoding with AC3
By Stankia in forum AudioReplies: 2Last Post: 25th Apr 2008, 19:44 -
AC3 dialnorm encoding
By RobinReumers in forum ffmpegX general discussionReplies: 0Last Post: 6th Jun 2007, 10:35
