  1. Hi ,
    We have a hp dvdrw i100(dvd+rw) , we use Tmpg Dvd Authoring to make a dvd with a vcd movie.
    It working and we can make a good dvd but we can burn it just on dvd+rw disk and we cna not burn on dvd+r disks ' we use a memorex dvd media.
    any help?
    Jan 2003
    Lighthouse Cove, Ontario
    uhmm... ok thats confusing.
    you can burn to dvd+/-RW but not DVD+/-R? What kind of errors does it give you? Does it burn but not play? I use memorex DVD+R's with no problems, using TMPEG DVD Author software aswell
    -Syndrome
  3. The good: Burns DVD movies or data on rewritable media; faster than competing DVD-R drives; also writes to CD-R and CD-RW.
    The bad: DVD+RW media is not as compatible with older drives and players as DVD-R; drive won't support upcoming (and more compatible) DVD+R media.
    http://reviews-zdnet.com.com/HP_DVD_Writer_DVD100i_drive/4505-3205_16-6913998.html
    However, the DVD100i won't be able to write to DVD+R without a firmware upgrade, which HP doesn't plan on providing. At least the company doesn't try to whitewash the compatibility issue--
    http://reviews-zdnet.com.com/HP_DVD_Writer_DVD100i_drive/4505-3205_16-6913998-2.html?tag=review
