When i import the movie i want to start editing this is the errors i come up with below
- cause: this file is a RAW PCM format without the headear
- You need to add the header with LPCM to WAV tool
Basically i captured mpeg2 video off my dazzle creation station 200
using the newest moviestar software (i cant find nothin else to capture from it like it suppose to be) .....
Download and install VirtualDubMod so you can demultiplex the AV streams in your source so that you can import just the M2V video stream. Then convert the audio to either MP2 or AC3 and you should be good to go...
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
It should present a menu asking you if you want the file converted. Does it not?
awlchu
Originally Posted by mol3000-----------------------------------------------------
There is a reason why God gave us one mouth and two ears!!!
DVD Lab Pro trouble with background and importing
By stantheman1976 in forum Authoring (DVD)Replies: 13Last Post: 3rd Apr 2008, 09:41 -
Importing Photoshop layers into DVD-lab PRO
By PharmBoy in forum Authoring (DVD)Replies: 5Last Post: 2nd Oct 2007, 01:09 -
DVD-Lab Pro Errors?
By Heineken in forum Authoring (DVD)Replies: 31Last Post: 4th Sep 2007, 15:41 -
Importing .PSD files into Dvd Lab Pro, and loosing image quality.
By mlong30 in forum Authoring (DVD)Replies: 1Last Post: 28th Jul 2007, 20:28 -
importing layers into dvd-lab pro 2
By PharmBoy in forum Authoring (DVD)Replies: 4Last Post: 16th Jul 2007, 17:44
