hi
just burned a file in nero>recorder, played the film but it's in letter box format is there any way of changing the picture format?
many thanks![]()
Basically you have to cut off the sides and re-size it, then re-encode it.
Alternately you can tell your player to do Pan-Scan, you will lose the sides. If it's Anamorphic you will lose about 1/2 the video (if you player goes 4:3) or 1/4 of the video (if you get a smaller letterbox). This all assumes your player can do Pan-Scan on the fly (most jsut do a fixed shrinkage, not the dynamic moving of the viewed area).To Be, Or, Not To Be, That, Is The Gazorgan Plan
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 16:25 -
How to burn or extract some CUE or APE files?
By diets in forum AudioReplies: 3Last Post: 21st Jan 2010, 11:43 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 07:06 -
Toast error message on .cue files
By Going gray in forum MacReplies: 8Last Post: 17th Aug 2007, 13:46 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 22:29
