Or at least, my windows applications show it as 360x240.
Apologies for semi- off topic. I am capturing analog, but the answer probably lies in the DV world.
I have captured via WinDv, Winproducer, and Vegas Video 3.0LE. The files thus produced all play in Windows Media Player, Winamp3, and Media Player Classic as 360x240.
Winproducer and Vegas Video 3.0LE show them as 720x480.
I'm leaning in one of two directions:
1. The ADVC1394 fakes 720x480 in some sort of DV way that the included software understands, but others do not.
2. My windows DV TypeII Codec is non-standard and doesn't decode the perfectly good files from the ADVC1394.
Anybody know which, know a fix, or have another option to condider?
Thanks-
Pat
Closed Thread
I *think* your problem might be the MPEG-2 decoder that WMP is using. You can find that out in File > Properties > whatever.
My Windows Media Player (version 8) doesn't have 'advanced' under "File>Properties". What version does?
THanks-
Pat
Ah. The interface to DV decoder in WMP 8 and 9 is under:
Tools>Options>Performance>Advanced
Rather than an explicit setting, there's a slider small-large. Setting it all the way to large in WMP 8 did nothing; in WMP 9, it makes the file show as 640x480.
Winamp3 and Media Player Classic still think it's 360x240. Gspot and AVICodec think it's 720x480.
I don't know how to prove what size TMPEG thinks it's source files are, but the wizard wants to encode my files as 352x240, which is at least a hint that TMPEG thinks they are not 720x480 - and what TMPEG thinks is what really counts, in the long run.
So WTF? How is it possible for there to be so many differing opinions as to the content of an AVI File?
Pat
Please do not cross - post, Locking this thread.
Continue here
https://www.videohelp.com/forum/viewtopic.php?t=207041
/Moderator - Bugster
Canopus ADVC 300 DVD Capture Now?
By Detta in forum Capturing and VCRReplies: 7Last Post: 20th Sep 2011, 14:02 -
How should I capture my hi 8 videos with my Canopus ADVC 100 and TRV460
By eichelman in forum Capturing and VCRReplies: 4Last Post: 9th Dec 2009, 14:21 -
Why DVD (720x480) bigger than AVI(720x480)
By psxiso in forum Video ConversionReplies: 6Last Post: 3rd Feb 2008, 06:50 -
Capture problem with Canopus ADVC
By BonnieW88 in forum Capturing and VCRReplies: 3Last Post: 26th Dec 2007, 21:20 -
Anyway to capture 720x480 using the Gamebridge and still play?
By Mysteriouskk in forum Capturing and VCRReplies: 0Last Post: 19th May 2007, 14:07
