  1. Just got my G5 the other day and finally got everything figured out, as far as using DVD back up and DVD2oneX goes. However, when i choose the DTS track, i hear no audio. when i choose 6 Ch or whatever else, it works fine and I can hear audio. My Home Theater has DTS because I have used it before with movies that I have purchased. Are DTS tracks not able to be copied with the current software available? thank you.
    Assemble your crew, I'll meet you outside.
    Jun 2001
    Silver Spring, MD USA
    If you are selecting DTS as your main audio on a full disk copy, and deselecting all the Dolby Digital tracks, you most likely will have to press the AUDIO button your remote control one or more times to select DTS. Even though it's the only audio available on your copied disc, it doesn't get re-mapped to be the first audio track. If it was third or fourth on the original DVD, its in the same position on your copied disc.
    The solution to make it the default audio would be to copy the original DVD in movie-only mode.
  3. thanks. i actually got it to work somehow. very impressed And, i only had to make 5 coasters...
