Hi,
When encoding for SVCD using TMPGEnc I alsways get jerky playback if I dont start the encoding from the start of the file. i.e. if i set up the source range to start from say half way through (or anywhere that isnt the first frame).
This is quite annoying as it means I have to encode a very large file in one go and then split it later for burning onto 2 cd's.
I have discovered from playing the resultant video that every so many frames, the same frame is displayed twice.
I'm certain i've set everything up correctly.
Does anyone have any ideas what may be causing this? Any help will be appreciated, Thanks.
Results 1 to 1 of 1
Smooth frame by frame accelerated video playback?
By Malachaidc in forum Newbie / General discussionsReplies: 10Last Post: 30th Jul 2012, 12:40 -
Couple of getting-started questions about HD editing, playback
By android25ua in forum Newbie / General discussionsReplies: 4Last Post: 9th Nov 2011, 15:08 -
Jerky playback
By hi2shy in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 30th Nov 2010, 17:44 -
Jerky Playback
By electrowiz in forum Video ConversionReplies: 1Last Post: 25th Aug 2010, 17:16 -
Jerky playback on TV from PC using TV Out
By digidude in forum Software PlayingReplies: 0Last Post: 30th Dec 2008, 18:26
