Using DVD Decrypter I made a large ISO of a Dual Layer DVD.
Unlike a smaller ISO I made from a smaller film the bigger one tries to start but then it stops playing in PowerDVD.It seems that the hard drive is looking for data as the drive light stays on.
I notice that PowerDVD in file mode only shows the larger ISO as the same size as the smaller ISO at 4Gb although windows explorer shows it as 6Gb.
This file also freezes in Windows Media Player.
I have tried defragging the drive but this file was not defragged.
I have now made a smaller authored backup with DVD Shrink but is this the only way out? I was hoping to have a set of ISOs rather than a mixture of ISOs and compressed titles.
Why create an ISO that size if you couldn't burn it anyway? Use DVD Decrypter in file mode and rip all the files.
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 04:16 -
Dual Layer problem. Layer break issue...
By papegoja in forum DVD RippingReplies: 23Last Post: 9th Jun 2010, 23:52 -
Dual layer disc error (2nd layer not burning properly - AVCHD)
By hhhgamewmx7 in forum Authoring (DVD)Replies: 7Last Post: 24th Aug 2008, 10:00 -
Question about backing up a dual-layer dvd (files vs ISO)
By bgart13 in forum DVD RippingReplies: 7Last Post: 19th Aug 2008, 01:16 -
dual layer DVD-R in single layer burner?
By snafubaby in forum MediaReplies: 5Last Post: 4th Oct 2007, 14:39
