I bought te full retail edition of Nero 6 and have used Nero VisionExpress a few times. I have noticed though, that it appears to be quite unstable. Several times after spenign hours transcoding an AVI file to DVD format, the program just crashes. No error messages come up, the program just dissapears. Anyone else experienced this? I have patched to the latest versions, and on the AVI -> DVD conversions that I have done, I am pleased with the results. I just wish that the bloody program wouldn't crash when I leave it on over night![]()
I had the same problem and came to find out that it was a corrupt avi file that was crashing it. I ran it through VirtualDub and it ran fine afterwards.
What I did was use the TV out of my video card to my VCR and when I set it encoding before bed, I used my VCR to record to encoding process while I sleep. Next morning I wake up to a crashed Nerovision, played back the tape and found which file it was crashing on.
It's a bit elaborate to find out why Nerovision is crashing, but it's worth it when some of your encoding jobs take 8-12 hours. -
One thing I forgot to mention, you need to make sure that your TV out settings for the video overlay are not set to fullscreen, otherwise all you'll capture is the video preview of what's currently encoding.
Originally Posted by a6equj5
The advice to check the avi for corruption is very good. I think you should also look into using a dedicated mpeg encoder like TMPGEnc for these types of conversions. The quality of your DVD mpeg will be better than the Nero conversion for sure. -
Originally Posted by teegee420
NeroVision Express 3 does not have chapter buttons
By Brent G. in forum Authoring (DVD)Replies: 1Last Post: 8th Aug 2008, 23:45 -
DVD-RW VRO to DVD in NeroVision Express problem
By ecc in forum DVD RippingReplies: 1Last Post: 30th Jul 2008, 00:17 -
Is somebody a NeroVision Express expert?
By jeanpave in forum Authoring (DVD)Replies: 12Last Post: 15th Sep 2007, 22:42 -
NeroVision Express 3SE: Return to the main menu?
By frankieg in forum Authoring (DVD)Replies: 2Last Post: 11th Jul 2007, 10:31 -
main menu music, nerovision express 3
By Reggie6966 in forum Authoring (DVD)Replies: 4Last Post: 10th Jun 2007, 07:00
