i have recently jst converted an AVI file to DVD and was wondering how i can now convert it from NTSC to PAL
If can play the NTSC version don't bother. you'll have problems with sync of audio. Most players will do the conversion for you and even if your player outputs NTSC your T.V. could handle it.
Having said that Compus ProCoder is supposed to do it correctly. -
If you still have the AVI and it's 23.976 fps and want to do a PAL DVD:
- Extract audio. Convert to wav 48 kHz.
Change AVI frame rate to 25 fps
Make audio wav shorter with WavWorks. (Or GoldWave Timewarp.)
Encode video only from 25 fps AVI to DVD m2v
Encode audio to 2 chan AC3 or mp2
Author m2v and ac3/mp2
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19
