I just got the Nec 2500D 8x burner, with 1.06 Firmware and it took me a little bit over an hour (35 mins to "copy to image" and 35 mins to write a 4.3 Gig of movie) and while it "Copy to Image" I monitored the rate , it was at 2200Kb/s and it wrote at 6x 11Kb/s for a 4x TDK+ disk, is this normal? I 'm a long time Nero user for CD-R but new to DVD burner and Nero 6.0. I used to use DVD X Express (not happy with it!) and it fit a 7Gig+ of movie into one disk, does Nero can fit this much of data into 1 disk? Or it will split (I'll be OK with split into 2 disks) into two disk? Thanks in advance for your answers.![]()
Becareful of using Nero 6.0 for -RDVD blanks, especially when linking from DVDShrink (uses the Nero image). I've had several failures but none if I use +RDVD blanks. TDK Tech support (for my burner) say that Nero 6.0 has problems with -RDVDs, but the latest upgrade may fix it (haven't tried myself).
How long should a DVD burner last?
By Regor21 in forum DVD & Blu-ray WritersReplies: 12Last Post: 4th Sep 2010, 14:31 -
Authoring a LONG DVD
By Huntr777 in forum MacReplies: 2Last Post: 5th Dec 2009, 16:10 -
problems burning with nero and imgburn-pixlation and long burn
By pokitisme in forum Software PlayingReplies: 5Last Post: 2nd Sep 2009, 03:12 -
DVDs on hard drive for back up and play back on TV
By yadoc in forum Video ConversionReplies: 2Last Post: 2nd May 2008, 21:03 -
Long videos in a dvd
By valtea in forum Authoring (DVD)Replies: 7Last Post: 20th Mar 2008, 12:21
